Want Stump Grinder
   / Want Stump Grinder #1
Avenger
Veteran Member
North Idaho
LS XR4145C
We just finished thinning my forest. I am left with hundreds of stumps to remove. Renting a stump grinder backhoe or excavator would be too expensive for the amount of work I need to do this spring. I thought about getting a backhoe attachment for my tractor, but they are really expensive too, more useful but double the price of a stump grinder.
I did some googling (and searching on here, but not much recent info on here) about stump grinders. I see different makes and models, people building their own, etc. I am looking to mow down stumps no bigger than 36in down as far as I can go. PTO driven with hydraulic lift and swing. My dealer, who deals in Woods Equipment quoted me $4600 I believe for this:
Product Details
I called around to other dealers, and most said they don't carry anything stump grinder related or 3pt attach grinders, or are stupid expensive.
I am not opposed to getting a backhoe attachment, if the price is right for the size. I believe I was quoted something like $11k for the LS backhoe from my dealer when I purchased the tractor.
If anyone has any info, I would greatly appreciate it. Thank you!
   / Want Stump Grinder #3
HOW MANY ACRES OF FOREST? WHAT SPACING BETWEEN TREES?
I am not a fan of stump grinders. Stump grinders are expensive to maintain. Price the individual carbide tooth blocks before you buy. Land is unsatisfactorily uneven to me after chipping stumps.
My preference would be to hire an excavator and operator for the work. The largest size/weight excavator that will fit between the remaining trees. A heavy excavator will remove stumps in less time per stump than a light excavator.
An excavator + operator will probably be your cheapest process to get those hundreds of stumps out.
VIDEO: EXCAVATOR STUMPS - YouTube
   / Want Stump Grinder #5
Stump Grinders are one trick ponies. Can't do anything else with them.
BH has a lot of potential uses.
HOWEVER, an SG will clear stumps much faster than a BH and probably do less ground disruption. They'll grind off at or just below the surface and leave nothing but chips whereas with a BH, you need to dig deep enough to break the roots and still need to dispose of the stump and roots. For a number of 36" stumps, I feel a SG would get the job done faster and cleaner. Buy it, use it, sell it. You'll get less than you paid, but the end cost should be less than rentals would have been.
Thats exactly my thought process. I wont really have a need for the SG when I am done. Though, I am sure I would use it maybe once or twice in 5 years, type of thing. If I buy it, use it, I am sure I will be able to sell it. The BH is more useful, but would take longer and then I have root balls the deal with, and huge holes. The BH is also way more expensive.
Renting an excavator is an option too, but at $800/day (just got a quote), if I buy the SG and sell it, I am still way cheaper than renting equipment and ending up with nothing. That assumes I can sell it, which I am sure of. Ironically, the rental company rents self-propelled stump grinders too! For $750/day and the guy said it will take about 20 minutes to grind a stump. Quick math says that's not gonna happen.
   / Want Stump Grinder #7
Differents cost between the two I would lean towards backhoe,good chance you'll have projects in the future.
   / Want Stump Grinder #8
If I had a hundred stump to remove I would get the grinder. What are you going to do with a hundred stumps.
   / Want Stump Grinder #9
Digging 30” stumps with the backhoe for your tractor will take forever and be very hard on the hoe and tractor. If the trees were just cut down, you might not even get bigger stumps out of the ground. It also won’t be comfortable for the operator either.
The backhoe attachments for these tractors are excellent replacements for your shovel, but are not industrial hoes by any stretch of the imagination.
Dont get me wrong, I LOVE my backhoe, but I have no illusions about what it is capable of doing.
   / Want Stump Grinder #10
I have dug hundreds of stumps with a trackhoe. It takes time and when you are finished you have a hole in the ground.
Gehl Mix-All Mill (A50515)
Gehl Mix-All Mill...
Woods RC4 3 pt Mower (A50515)
Woods RC4 3 pt...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
International Farmall 300 Tractor (A50514)
International...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
