Want help in locating MT20D parts.
   / Want help in locating MT20D parts. #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I broke the LF axle housing on my tractor. Looking for a replacement axle housing, complete axle or parts tractor.
Rebeldad1 in Washington State.
May also be interested in a 2wd MT20d axle assembly. Has anyone converted their 4wd to 2wd so they didnt have to scrap the tractor?
Also if you are in need of parts off this tractor let me know. I am trying to save it but also realize it may not happen.
Runs great
new tractor tires on front
good rear tires
Recent loader assembly with 4way valve.
   / Want help in locating MT20D parts. #2
If it is not all shattered but basically in 2 or 3 parts you should probably be able to get it welded by a good shop.
Cast iron can even be brazed but today they have special rods to ark or tig weld.
Even aluminum castings can be welded by a pro.
If the casting is the only damage I'd seriously look into that option.
Bearings and seals can be matched but when it gets to shafts and gears that is another story with MT tractors.
Good luck.
If I can find someone in the Washington state area who is REALLY familiar with cast iron I am going to get it welded.
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
