Want Advice on pruning my White Oak trees (pics)
   / Want Advice on pruning my White Oak trees (pics) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Getting ready to prune 36 White Oak trees that I planted up my drive. This will be their 4th summer. Regarding the tops, should I remove all but 1 branch to force a central leader?
   / Want Advice on pruning my White Oak trees (pics) #2
You will also need the advice of others in your area but for my Bur oak in Ohio I make a central leader and clear all side branches up to about seven feet or so. I prune in stages because you need the top growth for good root growth to get the tree started. After that I leave it alone-maybe clear a bottom branch or two.
As well, I broadcast some dry fertilizer around the drip line of the tree for the first 5 or 8 years and it really helps the tree recover from pruning and get a real jump start on growth. I use 19-19-19 the first year and then drop the middle number (phosphorous) to near zero in later years.
EDIT--In your photo above, the second from the right is what I would pick for a leader. It's the one the tree has chosen because it is stronger and taller.
   / Want Advice on pruning my White Oak trees (pics) #3
I have two oak trees and I prune them just like my hawthorne and locust. I do basically as sixdogs says. Check the internet for local advice. My biggest problem for young trees is pocket gophers.
   / Want Advice on pruning my White Oak trees (pics) #4
I don't know when to prune the top for the leader but I would prune the bottom branches where the leaves are now.
I did this with pin Oaks and the subsequent growth was impressive to me.
Mine were about that size when I started pruning. I didn't do it all in one year. That was 20 years ago now they are nice specimens.
No pics because I sold the property about 10 years ago. But I drive by once in awhile.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
1267 (A50490)
1267 (A50490)
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
20711 (A50323)
20711 (A50323)
CATALOG UPDATES (A53084)
CATALOG UPDATES...
