Walco Douglas 72inch side discharge finish mower
   / Walco Douglas 72inch side discharge finish mower #1
boltz
Ontario Canada
kioti ck30, allis d-17, Cub Cadet Enforcer Zero Turn Mower
Help. Need to know if bolts that attach blades should have concave washers to hold blades to spindle. Mine were all loose. Phoned WD here in Ontario, gave them part number, asked if washers were concave, lady thought so. Ordered washers, was shipped flat washers. Would appreciate some experienced advice. Thankyou. ( Edit. Some mowers, Woods I believe use the concave or Bellville style washers to prevent loosening due to vibration. Now that there is play where blades mount due to being loose, any suggestions to save buying new spindles and blades.?) Also washers WD sent are 5/8 not 1/2 inch hole. No one stocks concave where we live or wants to order them.
   / Walco Douglas 72inch side discharge finish mower #2
I have a 84" finish mower (3 blades) and only lock washers used. Had it for 8 years and no problems with loose bolts/blades.
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55302)
1992 Talbert 70...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
14179 (A55788)
14179 (A55788)
