Wagon Gear hub and bearing replacement/repair
   / Wagon Gear hub and bearing replacement/repair #1
nckennedy
Camillus, NY, USA
JD 5425
HI Guys. I purchased an old wagon gear to put under a chicken pen. The wheel bearings are bad, wobbles a lot. I removed one wheel and discovered what seems to be a really old style hub and bearing. Just wondering where to begin looking for parts. The hub is eight hole lugs (bolts actually). Hub has a number 690 on it and maybe an old IH stamp on it. the cylinder ball bearing number is 8678T (timken??). The hub cap is numbered with 587 WA. And the retaining washer/nut is numbered 686 W. The hub interior appears to have a split sleeve, which appears to be the problem. The bearing that slides into the sleeve us way to small or the sleeve is way to big. Must have worn down over the years. Can that sleeve be replaced? Have to be pressed out but have no idea how to find a replacement, etc. Any suggestions. Craig
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
Adams 5T HC Spreader (A53472)
Adams 5T HC...
20ft Shipping Container (A51573)
20ft Shipping...
