Wadded my curl cylinders on my Mahindra 2655
   / Wadded my curl cylinders on my Mahindra 2655 #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Title tells it all. My fault. They are dead. Now to replace. I cannot find a cylinder online that is the exact matchup to Mahindra but Mahindra wants 2100 plus tax. Not happening. They are 29.26 eye to eye retracted. 1.4" cylinder. 2.75" bore. Pin is only 1". I have found close in 1.25 and may run spacer. Top width is 2.75 opening to mount and bottom is 2.25" width to mount. I am close on one that I have found. These are 3k psi cylinders. I do not think I will find exact. I have no interest in getting these fixed as no time. I need to get it to work. Does anyone have a place that ships fast and has fair priced cylinders?
   / Wadded my curl cylinders on my Mahindra 2655 #2
The problem is even a small change in length or diameter will radically change the forces- which could cause damage and or make the curl too fast or painfully slow or bend the frame.
The loader may he made by Kansas Metal Works?. They may have the cylinders.
KMW Ltd. Front End-Loaders & Backhoes
Cannot find an exact on either one of those sites. Was there earlier. My one inch pin seems smaller than most. Everything else is very close.
   / Wadded my curl cylinders on my Mahindra 2655 #5
As long as cylinder's are same side to side , Close in After market is likely as good as it will get . I recently lost a seal in a stabilizer cylinder on my 757 BH . I found virtually a exact match BUT for the hose connections . Stock cylinder , the hose's run along the cylinder and connect at a 45 . After market cylinder's , all had a straight in connection . Due to the extremely tight area that cylinder fit's in , those were not a option . Price for the after market cylinders was the same price as a rebuild kit , so I ended up just rebuilding .
I would think that I would prefer a shorter cylinder versus one to long , when in the closed position . That way the bucket would curl up at least the same as now or the way it was .
Fred H.
   / Wadded my curl cylinders on my Mahindra 2655 #6
Not trying to be callous...but got any pics for the rubberneckers and gawkers?
I do but not that good with them on here. Picture them looking just like a hockey stick. Maybe worse :) I did them right.
   / Wadded my curl cylinders on my Mahindra 2655 #8
If the pin size all that is off they make bushings.
I think it is my best interest to just call Northern Hydraulics Monday and see what the pros think. I will have to work a diff tractor this week but it is what it is
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
