W4 carb problems
/ W4 carb problems #1
Schoony
Lumby British Columbia Canada
1942 McCormick W4
I have cleaned and reset my carb but it floods so bad it fills the crankcase with gas but won't run without the chock on
/ W4 carb problems #2
Have you checked to make sure the float is closing? Years ago, I forgot to run the carb dry before the winter on my 1953 JD 40. Apparently, there must have been some water in the carb and it froze during the winter. The float was made of metal and was crushed a little by the ice. That caused a crack to form between the two soldered halves of the float and the float filled with gas so it could not close. I discovered this when I noticed I was using a lot of gas and then saw it running onto the ground. When tearing down the carb, I found the cracked float, drained and dried it out, and re-soldered it. It has been fine ever since.
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
