Knight9
Veteran Member
Hi all,
We are considering a pole frame constructed garage/workshop/storage shed. It hopefully will look similar to the picture here <A target="_blank" HREF=http://www.barnsbarnsbarns.com/noff/elmridge.html>Pole Barn </A>.
The issue is this. We have vinyl siding on our house and would like whatever we build to match as it will be very close to our house.
I've talked to two contractors so far. One said it was no problem to put on vinyl, they would just have to sheet the exterior with plywood first. The other said no way, you don't want to do that. It may heave and crack.
Does anyone have any experience with vinyl on a pole building? Is this feasible or do I need to look at a standard frame construction on a frost footing? We are in Alberta so we do get cold temps....but we use vinyl on most houses up here.
Thanks,
Kevin
Thanks,
Kevin
