I am thiking about building a shed open on 4 sides for drying lumber. I currently use vinyl siding glued together at the seams (w/ silicone rubber) to make panels which I overlap on the stacks and weight down with waste lumber. It allows air to circulate, is sufficiently self supporting, long lasting and has been very successful. So, I thought why not build an open shed, use some of my many pine boards to cover the rafters completely and instead of 5V galv, use vinyl siding. It would have a solid surface to be nailed/bonded to and seal the lapped panels with Si rubber. It would be cheap (5v galv would cost me $1000 +) but would it be crazy? If I do it, how should I orient the vinyl "boards", like siding is oriented or 90 deg from that?
