Vidio of tractor Fel and Box blade
   / Vidio of tractor Fel and Box blade #1
Timber
Veteran Member
East Bridgewater Massachusetts
Kubota B7800
This is 24 minutes so if you don't have time or your on dile up maybe you don't want to click on this. This is me and My B7800. I am re grading the soil that will be under my deck and around the pool
   / Vidio of tractor Fel and Box blade #3
nice video! gutsy little machine you have there too.
I think it is 10 minutes that is the limit of Photo bucket by the clip. That was my 1st attempt using my camcorder.
I am really glad I went with a 66 inch box blade. Having it a little wider than the loader is great when your up against the foundation
The straw hat is a tractor must have LOL
   / Vidio of tractor Fel and Box blade #5
so does everyones HST sound like that? (mine does)
   / Vidio of tractor Fel and Box blade #6
I watched the whole video Charlie.
You sure know how to work that tractor! You whipped out that area in no time flat. Great combination showing off your tractor skills. Another I noticed is your fel is pretty quick.
Thanks for sharing.
LOL thanks Rob,
I Love the Boxblade in combination with the loader. They are a perfect match for the work I am doing hear. Today I did the other side of the pool were the Koi pond is going in. I want to have everything graded and seeded tomorrow. I will be starting the New deck next weekend. I want to get the lawns started so the dirt doesn't all wind up in the pool. I think I will take some more video tomorrow. I still haven't figured out how to take a longer video and break it into smaller pieces. I will though
   / Vidio of tractor Fel and Box blade #8
Timber, did you ever try to scrape small layers off, working from a flat ground ? That's how i find my loader on the Zetor 5245 works best, with the 2 meter bucket. Probably HST gives you more control of wheelspin, not digging up everything by taking the pedal back to give the front loader a break, so it can lift the bucket a bit before you continue pushing.
I allways try to scrape off a layer thin enough so that my wheels dont spin, so i get max. grip working from flat ground.
Is there a noticable difference of bucket with teeth, vs. without teeth ? I am thinking of welding some leaf springs on my bucket, at the company i work, we also do full air suspension conversions to light commercial vehicles so we've got lots of leaf springs to scrap... spring steel is allmost as wear resistant as manganese. Just for me, old leaf springs are allmost free !
Yes the tooth bar makes a huge difference digging into the ground. If I didn't have the tooth bar I would have to do it the way you describe. The teeth do pull the bucket down anyway. I find curling the bucket is the way to dig with it. I can move quite a bit of material in a short time using this method and the box blade takes care of all my back dragging. I also find that with a loader full of material the the box blade works much better with the 4 wheel drive. Traction and all. I have always been a big fan of the tooth bar. I think if you are going to weld a tooth bar up take a piece of 3 inch X 3/8s stock the with of your loader and weld you teeth to that. Tack it into the bucket on the back side and bolt it through the bottom. Then if you need to take it out for some reason you can just wash the bolts and snap the welds. It will also strengthen the cutting edge quite a bit
   / Vidio of tractor Fel and Box blade #10
Timber, A picture is worth a thousand words. Nice Video. Thanks for taking the time to film your FEL and Box. I have been wanting to see just what it does and now I now. Great Job.
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
