Mowing Videos Brush Hogging a Sugarbush with CK-20
   / Videos Brush Hogging a Sugarbush with CK-20 #1
malk315
Lancaster, MA
Kioti CK20 HST
Hey Guys-
Hooked up a Bush hog brand cutter to the CK-20 today to mow down the weeds at a sugar maple tree site we created for a Cubscout project with a grant we actually were able to get from state of Massachusetts. Being the scout pack needs to maintain the land we need to brush hog it every so often as you can see in the videos. You can see the nice maple trees (one dead one -- we lost only a couple) I think it's got about 65 trees or something.
I was surprised it did as well as it did (the guy in the video is a buddy of mine and his friend let us use the hog). We could go pretty quick through the lower areas and the super thick clover was the only areas we had to go nice and slow or the RPMs would drop. Other than that it was very hot today so we had to watch the temp -- had to let her cool off a couple times -- even running my 60" mid mount on days like today can push the gauge up there. I guess this a 6' hog which I've read here is really too big, but I think we did ok. We never overheated.
The only real issue was getting the bottom arms on the 3 point to spread when attaching / detaching -- it was a bear. I have a rotary spreader and a trailer hitch adapter that go on easier but no other attachments to compare to. Any tips you guys have? You can see in the videos the drive shaft is fairly level and it's on the arms all fine -- I'm also not sure of the top link adjustment. Any tips there would be appreciated. It's probably a bit too heavy also as I couldn't pick it up much past 8 on the lift lever w/o it feeling like a pressure relief or something was kicking in. I can see there's a set of holes to lower the bottom studs -- maybe that would have made it better.
I had one brain lapse where I let off the clutch w/o realizing PTO was still engaged. I've done that same brain lapse once in the past w/ my own mid-mount deck too (I'm sure some of you may have done this too...). Machine is 6 years old about 350 hours and is HST so clutch only used to start PTO -- hope I didn't do damage there... I'm still mad at myself on that one. Don't ya hate when you do that? I figure if down the line it needs work (clutch or whatever) I'll do whatever it takes -- the machine is worth it. Everything seems fine -- no problems engaging and disengaging.
Anyway -- On to the videos -- first one has youtube's shaky video correction so the motion looks a little funny:
Brush hogging Pack 9 Sugarbush - YouTube
2012 06 23 15 21 09 46 - YouTube
2012 06 23 15 19 21 525 - YouTube
The seat time was very therapeutic today -- I'm a desk jockey and can only play on the weekends.
Well today we graduated to a JD5400 with a flail mower. Seems the flail or the hog do just fine with this stuff.
The flail had a beat up belt on it (chunks missing causing slip -- knew the squeaking and lack of spinning flails something was up). Quick trip to tractor supply (not much else open on Sunday) and a new kevlar re-enforced belt nothing was stopping that flail mower after that! Handled it perfectly and CK20 got a much needed rest.
JD 5400 with flail mower - YouTube
   / Videos Brush Hogging a Sugarbush with CK-20 #4
Malk neat video,looks like it was cutting good too !
I have fought that "BEAR" attaching/detaching and whipped his arse with a crowbar !
Boone
Yeah -- now I know why Bruce has a sledge hanging around his slew of attachments. Little coaxing with sledge handle and a tap here and there worked for us.
Bruce is the guy who owns the hog, flail, york rake, saw an RFM sitting there, a few different buckets -- he owns JD5400 we used today.
What a difference once we got the flail dialed in. Either attachment was going right through that stuff. When we had the bad belt on the flail we were ready to switch to the hog (Bruce came by and was thinking hog would be better too) but nothing was stopping it w/ new belt. Also the flail was a little better with avoiding the inevitable rock here and there.
   / Videos Brush Hogging a Sugarbush with CK-20 #6
a set of carter's quick hitch would help with the hitching and unhitching.. I happen to have a set for sale.. I don't need them any longer since my new tractor has telescoping lower links and side sway adjusters. Or a set of Pats if you prefer: some links below. I think you can buy the pats on this forum for a discount. the carters are cheaper overall. mine are cheaper yet.:)
Welcome to CARTER AND SON'S TOOL AND DIE
Pats Easy Change 3 Point Hitch System
James K0UA
Wow... Thanks for the tip... That is a great solution. Thanks for sharing.
If we did this more often or I get more larger attachments I'll seriously consider this. Great idea, and simple.
James K0UA
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
(4) Montreal ST 205/75 R15 Tires (A50121)
(4) Montreal ST...
Kubota RTV500 (A47384)
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
