Video Cameras
   / Video Cameras #1
Rancher Ed
Texas
2008 Kubota M7040 4WD w/loader, 1979? Mitsubishi D2600 4WD w/loader
You guys seem to know about everything so hopefully you will be able to help. We are thinking about getting a video camera and I have no idea what to look for. What we are looking for is good videos and also we want it to record sounds well. We also want it to not be too expensive.:D
On the sound thing, we would want to be able to record violin recitals, singing, etc. and have it have a good quality sound track.
I have no idea how to tell if a camera will have good audio so hopefully you guys have suggestions on specific cameras or what to look for in genral.
Thanks, Ed
   / Video Cameras #2
I have a flip camera, but
Cisco recently announced that it will be exiting the Flip business and support customers and partners with a transition plan. More information can be found at Cisco’s consumer website.
That being said you may be able to pick one up on the cheap, i have had zero issues with mine, and it does a great little job. You can carry it in your pocket and is youtube ready.
   / Video Cameras #3
I bought a refurb Canon Vixia HF200 for about $400. It uses SDHC cards which make uploading to your PC fairly painless. It also has a 1/8 external mic input and automatic or manual audio metering. I use it to record performances by a children's choir and run a line off the soundboard into the camera. The audio and the video are good. This really cuts down on the coughing, baby crying, and misc. audience noise if you capture audio off the soundboard instead of using the mic on the camera.
Not too many video cameras have external mic inputs these days.
   / Video Cameras #4
Above post is good. The Canon Vixia series is good quality, very easy to use. We have one for church use and everyone gets good results.
Sound can be difficult with any hand held video camera, but external mike can help a lot if you want to go to the trouble.
Whatever you decide, make sure you go with full HD capability and flash card recording. I'm in the market for a new camera, but I have always found I get better results with a viewfinder (In addition to the flip out screen) because I get steadier video and can avoid the glare problems outside, but that feature now moves the price point way up.
   / Video Cameras #5
Good advise - make sure you get a mic port, on board mics will not provide good audio. You will want to have an ext Mic to the center of your sound source and run directly to the camera.
Good luck
   / Video Cameras #6
Good luck
   / Video Cameras
Thanks guys. Sounds like none of them are going to have a good built in mic so just make sure it has a mic port to plug an external mic into? (or the sound board if stuff is already miked)
No doubt we would get one that uses the SDHC cards and it sounds like a mic port also goes on the must have list.
KennyG, I don't know anything about video cameras, what is a viewfinder?
Thanks again guys,
Ed
   / Video Cameras #8
It used to be that all video and still cameras had a small window on the back that you look through while filming/shooting to compose the image. With the low cost of LCD display panels, most video cameras now just have the flip out 2 or 3 inch screen that you use to watch what you a filming.
This is all fine except that if you are outside with the sun behind you, you won't be able to see much in the screen. A viewfinder solves this. The other issue (which may just be my problem) is that when you use the screen, you are holding the camera out a foot or more from your body, so it tends to move a lot. With the viewfinder, you can hold it against your forehead, which is much steadier.
The downside is that cameras with viewfinders tend to start in price at $600 to $800.
The in camera microphones are pretty good considering how small, cheap and badly located they are. :confused2: There's nothing worse than trying to film a performance and picking up stray conversations, footsteps, etc.
   / Video Cameras #9
We have a Cannon ELURA 100. It Has a 20X optical and an 800X digital zoom. It uses both a mini-cassette and an SD card. You can use either one for video or still photos. We usually use the cassette for video and the SD card for still photos. It has both a viewfinder and a flipout viewer. We have used it to record church services with good results. You have to be careful with the mike because it will pick up your breathing and perhaps other sounds that you may not want to record for posterity.
For things like church services and violin recitals, you will need a good tripod and a remote control. Our ELURA came with both.
We download to an older PC running Windows XP Professional to make DVD's for video's or to CD's for still photo's.
   / Video Cameras
Thanks KennyG, that makes a lot of sense. My camera has one and it is very nice when it is sunny, I just never knew what it was called.
The Canon VIXIA HF S30 looks really nice. Has a viewfinder, mic port, an optional 5.1-Channel Surround Microphone that mounts on top of the camcorder that looks very nice, etc. but cost ~$1,000.
The Canon HF M301 (Costcos version of the VIXIA HF M300) on the other hand, doesn't have a viewfinder but has all the other things the HF S30 has and only cost ~$350.
Everyone is recomending canon, what other brands should I look at?
Ed
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
Bucket (A55973)
Bucket (A55973)
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
