About 15 months ago I purchased a WC-10H PTO Wood Chipper with Self Contained Hydraulic System. I am just finishing the review, and it is not pretty. Has anyone else had any experience with one of these? There were a couple of items in the instructions that did not match, but not too bad overall. We were able to get it together without too many issues. I have a MF-285 tractor which along with a number of other similar MF tractors are prolific across the country. When we connected it us and got ready to install the PTO shaft it took a lot of figuring to get it the right length. We finally got it installed and attempted to start it up. It sheared the bolt right away. Installed a new one and the same. Checked everything out and all seemed to work correctly. Purchased some #8 bolts though that was not recommended. After three more shears the PTO broke. Contacted the sales rep and they sent another shaft and some more bolts. As I travel most of the time, I only had 3 weeks to work with this. Came back for 3 weeks in the fall and work on it for a while, but still never able to get it to run. No workable solutions from the manufacture. Came back in the spring and started off with the basic trouble shooting again. Found out that the instructions for the operations was incorrect. With several trial and errors, we got it to run. What joy!! Then it clogged up after just three branches. Found one video online on how to adjust the spacing for the blades - and it was a hideous video - and we worked at getting the blades corrected. Ran a couple of more limbs through and it appeared to be working right. Then it clogged again. The machine gets VERY HOT. Even on a very cool day.
The PTO shaft broke again - the collar - so we gave up. At a lost on what to do to get this to work. The sales rep asked a couple of questions, but the only solution appears to spend $500 on a slip clutch for a +$4,000 unit.. Don't see how that will fix the extreme heat of the unit, or the clogging.
I look forward to any working solutions anyone would have. I would add that we got the heavy duty flail mower from Victory and my boys say it was the best purchase we ever made. The gear box went out the first day and they promptly replaced it and we have over 100 hours using it.
