Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,568
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
One year old - bought almost exactly 1 year ago to replace my ancient Prest-O-Lite regulator. Apparently a bad move.
I use it very sporadically. Today I tried. When I went to adjust the Acetylene pressure with the torch valve closed it was jerky not smooth. It would go putt and the pressure would jump up. It would continue like that - putt putt putt. Then it would just sit steady until I opened the torch valve and it would putt putt again. The pressure would jump from 3 to 6 psi on each putt and drop from 6 to 3 psi between putts. I nervously lit it up and the flame pulsed as you would expect. After a while ( couple minutes ) the pressure stabilized a 6 psi with a smooth flame and no more putts. If I tried to change the pressure setting it would start pulsing again. At that point I shut it down.
I am trying to figure what to do next. Any help would be good.
gg
gg
