vibrations when clutch is released
   / vibrations when clutch is released #1
Dlamb56
salem,mo
mahindra 3510
Started hearing noise from bottom of trator when tractor was put into forward or reverse. Sounds like more of a vibration internaly. Then it will disapear and sound and work fine until the clutch is pressed again. Any ideas? Sounds like clutch work to me or a throwout bearing.
   / vibrations when clutch is released #2
I'm going to agree and say that I think it may be the throwout bearing.
   / vibrations when clutch is released #3
broken spring in clutch disc would be my bet, if clutch is adjusted properly the throwout bearing will only make contact when clutch is in I would think you would also feel or hear this vibration as soon as you took up free play and bearing made contact with pressure plate and as soon as you let up it would go away. regardless sounds like you are going to split the tractor for a look see.
Thanks for the replys. Will call dealer today and see when we can get it in and his thoughts.
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2018 Ford F-250 Reading Enclosed Service Truck (A50323)
2018 Ford F-250...
2003 Honda Element SUV (A50324)
2003 Honda Element...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
