Very Unhappy
   / Very Unhappy #1
kenstrac
Platinum Member, RIP
So central NH.
Kioti DK 45
In the spring I bought a KK II 6FT rototiller 7FT rake and a 6 FT box blade from TSC, hooked it up and did a dry run on the tiller the chain on the shield snapped and went flying after 4-5 min of use and the PTO shield was cut.The roll pin had come out of the shaft to u joint connection .Brought it down to TSC and they said they would get me a new shield,About 5 weeks went by and no shield, needed to rototill drove pin back in and used it did less than150 sq FT of garden pin is coming out again drove it back in and put hose clamp over roll pin and got it done I called KK directly and told them of the problem and they said it happens occasionally and sent me out a new PTO shaft complete in 3 days good service on KK's part and I am happy with the tiller. During this time my neighbor brings over 17 loads of horse manure mixed with shavings I spread it out with the FEL and then rake it with the Farm Force rake the manure I was raking was no more than 1 FT deep at the highest point when I got off the tractor I noticed the rake was twisted a bit and the canter tines were lower than the ends.I called TSC and the dist. mng told me that the rake was not designed for that HP of a tractor and to bring it back . Yesterday morning I hooked up the box blade and went down to a brushy area that I wanted to clean up, went over back and forth with the FEL to loosen it up most of it was 1-2 in dia and a gravel base .I then used the box blade to finish pulling up the root system after about 6-7 passes the box blade was bent up 45 deg. the top link to box blade supports were bent like pretzels.another Farm Force piece of equipment.
IMO the rake and the box blade should have a CAT 0 rating, I have had other brands of rakes and box blades in the past that were CAT 1 and used them on CAT 2&3 on 60-125 HP tractors and never had failures like this.
BTW this is being used on a DK 45 in 2WD .
   / Very Unhappy #2
I had the same 7' Rake on my 3520 and had the rake twisted like a pretzel in 60 minutes...LITERALLY...the time stamp between the Purchase reciept and the Return reciept were less then an hour apart....
I knew they werent the best implements around, but sheesh, less then an hour of light duty use?
   / Very Unhappy #3
I'm using a JM354 (35hp) Jinma with my KK 6' rake and it's says Five Point by KingKutter on it. I have their 6' box blade the 6' professional series rear blade and 6-1/2' disc and I use their tiller tines on my tiller and all have performed very well. I will say the rake has a few tweaks or bends in the main angle iron beam, but still works fine. It's all cat 1 stuff and most of it I've used for over 5 yrs. now. If asked I'd say "Yes, I would buy it again". bjr
   / Very Unhappy #4
I was torn between a new boxblade from TSC and refurbishing an old GIL in pretty bad shape. I estimated that it would cost me as much to refurb the GIL as a new box from TSC. But, then when I compared the quality, I quickly realized that the GIL was way better made. While the refurb was a lot of work, I think I ended up with a boxblade that would be hard for my little tractor to tear up, and its weight will improve its effectiveness. Those light, soft things from TSC.... I don' think it would take me long to bend them up.
   / Very Unhappy #5
So, you bought the cheapest, made in china, lowest quality, lowest priced equipment around and it didn't last.
What did you expect?
Honestly, there is certainly something to value, and the most expensive item may not be the best, but you certainly weren't paying for quality and guess what? you didn't get it.
I'm not seeing the issue.
   / Very Unhappy #6
Since KK treated him well when he contacted them and implements that fail to perform reasonably can be returned to TSC, in that sense I agree that there isn't an issue. However it isn't unreasonable to expect a Cat 1 rated implement not to be significantly damaged within a short time especially if doing only light duty work. We're all looking for value when making purchasing decisions and I find these types of brand specific reports useful.
   / Very Unhappy
Well I do
I sold IFC implements Rakes ,box blades, post hole diggers, brush cutters,etc and never had a warranty issue I even rented out some of the equipment.they were a low price line. Other than looking like they were painted with a mop they worked well and they performed well above my expectations for the money spent.
The rake that I bought at TSC IS made in the USA the poor design of the rake (sectioned bottom tine holder ) is where it bent and twisted.
The box blade also made in USA back brackets should have had a brace half way down to stop it from bowing ,and as I was removing the brackets to make new ones I noticed the powder coating had a hair line crack the whole length of the square tubing on the top where the teeth come through,Now how much does it cost to put the seam in the rear so this will not happen $0
   / Very Unhappy #8
Farm force has not impressed folks around here (TBN)! Woods,landpride,sitrex,demco, buy it once.
   / Very Unhappy #9
oh....you only get what you pay for in life.....
Lesson learned!
Craig
   / Very Unhappy #10
I guess I have taken my Modern box blade for granted. Its done some pretty tough work with packed limestone and held up well.
   / Very Unhappy #11
Have heard there has been many problems with the Farm Force line that TSC started carrying. I think some of the stores have dropped the line all together. Now the KK tiller has been a good piece equipment for many of us. Sounds like bad luck on that one. I am glad that KK and TSC are treating you fairly.
MarkV
   / Very Unhappy #12
This is a lesson I have certainly learned the hard way. I had a Howse dirt scoop that lasted a day. Get one of the top line attachments and buy it once like someone else said.
   / Very Unhappy #13
Too bad you had a problem with your Howse dirt scoop. Mine has served me very well, and I use it hard with my Ford 3000. The only thing I dislike about mine is that it wont work with my QH. But then, all dirt scoops may be that way.
   / Very Unhappy #14
Buy once...cry once.
Yeah, it's hard to put out the big bucks for the better quality stuff, and true, sometimes the cheap stuff works out... but not as often as we would like.
When I buy something that is quality, in a short time I can't remember the price. But after buying a piece crap I can remember the price forever!
Paul
   / Very Unhappy #16
Paul
Very well said!!!
Eddie
   / Very Unhappy #18
I just bought a Farm Force chipper from TSC, which I believe is just a Jimna chipper with painted yellow. Very dissapointed. Came in with metal damage, missing nuts and bolts, bolt holes that dont line up and directions that dont tell you a thing. I finally get it set up, chip about ten 2" branches and the thing breaks on me. The steel on the anvil actually cracked. I knew I was buying cheap, but I thought the quality would be a little better then that. Now I understand why american made chippers are more exspensive. You don't always get what you pay for, but you always pay for what you get!
Kevin
2007 Volvo VNL Truck Tractor (A61306)
2007 Volvo VNL...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
207281 (A52708)
207281 (A52708)
2017 Versatille 260 (A60462)
2017 Versatille...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
