Vertical dig depth
   / Vertical dig depth #1
Seven Gables
Platinum Member
Northern lower Michigan
jd 5115m , Ford 545D, Kubota M8540, NH t4.105 , Ford 5030, Ford 4830, NH TN 95FA, Volvo EC60E
I've got a Volvo ec60e 6ton mini excavator that came new with a werk-brau 2 ft heavy duty bucket. Like pretty much everything about it except it won't come anywhere close to the 9'6" vertical wall dig depth that the specs claim it will. Talked directly to werk Brau about it, they said it is the correct bucket made to the exact OEM specs as the Volvo bucket. I do have the hyd pin grab quick coupler but don't believe it is effecting the vertical dig depth in a negative way much. It needs to have about 15 degrees more out swing to be correct and give me the rated 9'6" vwdd. (Pin holes on bucket need to be angled down more). So far I haven't found a OEM Volvo bucket to actually compare pin hole to bucket floor angle with. It might do 2' vwdd the way it is, not even close to what it is suppose to. Anybody run into this with your excavators? Thanks in advance .
UNUSED 2-Ton Lever Block (A50860)
UNUSED 2-Ton Lever...
(2) Heavy Duty Tow Straps (A50860)
(2) Heavy Duty Tow...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A48082)
2009 Skeeter SL190...
2021 Bell B30E Off Road Dump Truck (A50860)
2021 Bell B30E Off...
1-Pallet Misc. Power Tools (A50860)
1-Pallet Misc...
