Vents
   / Vents #1
MODiesel
Missouri, USA
Kubota L5030HSTC
You know...
There I was last night, doing a little bit of maintenance and clean up on my TC29D, and it occurred to me that I couldn't find a vent anywhere on the chassis. Not on the front axle, the rear axle, or anywhere on the transmission/gearbox housing.
Hmmm...
Knowing that my truck has vents on the axles, tranny and x-fer case, and seeing them on larger tractors, I was curious as to how NH vents those components. I mean, heat and lube oil breakdown is bound to create some gaseous components. How is the pressure relieved? One would expect seals to give way without some release of pressure. Yet, in looking over things, I couldn't find an outlet.
Anyone know? Now I'm curious. /w3tcompact/icons/smile.gif
Best Regards,
Jay
   / Vents #2
I just got tc35d and checked front axle lube and noticed air (pressure) excape around dip stick when loosened.
I found vent for rear axle on top of axle in center under fuel tank.
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
John Deere 843 Corn Head (A50514)
John Deere 843...
2013 CATERPILLAR 336E LH EXCAVATOR (A51242)
2013 CATERPILLAR...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
