Ventrac 4500Z stops running unexpectedly
   / Ventrac 4500Z stops running unexpectedly #1
Randy Miller
ventrac 4500Z
I'm running a 4500Z with the Kubota engine. The machine has 800 hours on it I'm now having troubles with it stopping unexpectedly. Sometimes it quits after 5 minutes and sometimes it will run fine for an hour. Seems to idle forever fine but as soon as it's under load the issue begins. I use ethanol free gas, I tried choking engine when it was about to die and I could see some blue flame from the muffler few times i did that. It acts like its starving for fuel.
It will immediately re-start after stalling and might run 1 minute or 10 before stalling again.
I need some help anyone have any idea's? Feel free to email me or just reply. I dont understand how it ran fine for almost an hour and then it started sputtering and died, but would start back up and idle fine, just not do anything once I put load on it.
   / Ventrac 4500Z stops running unexpectedly #2
I'd start by checking/replacing the fuel filter at least, just to eliminate a possible simple solution.
turns out it was the vent line to the gas tank, it was plugged up, i blew it out. Used this weekend ran like it was supposed too
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
36'' Mini Excavator Bucket (A51573)
36'' Mini...
12' CONTAINER (A51248)
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
