Ventrac 4231 Sickle Bar
/ Ventrac 4231 Sickle Bar #21
I also looked at the old Haban and i see it could be easily mounted on the front and it would drive off the front pulley and a a cylinder raise and lower the bar plus you can raise the whole unit with the arms. I think this will keep me out of trouble when i try to get too close to the edge.
/ Ventrac 4231 Sickle Bar #22
I actually got the stuff to make one years ago. It was a little sickle bar mower off of a Gravely tractor that had the sickle bar mount on the side of it.
/ Ventrac 4231 Sickle Bar #23
There you go, what drove it a belt? most Gravely were center mounted i thought..
CAT Chassis Only (A59076)
CAT Chassis Only...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
96in. Fork Extensions (A61567)
96in. Fork...
Patterson water pump (A59230)
Patterson water...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
