vented cap on front axle overflowing - LK3054
   / vented cap on front axle overflowing - LK3054 #1
drassists
Charlton, NY
Kioti LK3054
I have fluid leaking out of the cap to the front axle case. I see there's a hole in the cap and from the looks of it, that is a vent.It's not overfilled and the fluid looks like it's coming out of that vent hole, almost like it "boiling over". I'm thinking there's probably a simple explanation to this, one that I don't know . . .
   / vented cap on front axle overflowing - LK3054 #2
Usually it means you have water in your oil, if it happens after you use it for a while, it froths the oil and water then it will push out the vent.
   / vented cap on front axle overflowing - LK3054 #3
Drain a little out. If it looks like creamed coffee, its got water in it. If it sits for a few days, any water will drain out first. Could also be over heating or foaming. Are you sure you have the correct oil/fluid.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
Cub Cadet 7254 Compact Tractor (RUNS) (A50774)
Cub Cadet 7254...
1996 JCB 6K42 6,000lbs Rough Terrain Telehandler (A50322)
1996 JCB 6K42...
Rhino MD-84 (A50121)
