veggie oil
   / veggie oil #1
automech
SE PA
bx1500
I have been trying to learn more about biodiesel and veggie oil. I have read that in order to run on unprocessed veggie oil, a separate heated tank and filter system is needed. What would happen if you poured some veggie oil straight into the fuel tank? Just filter clogging or anything more serious? Another question about veggie oil- since a separate tank and I assume a more porous filter is needed, does the veggie oil filter allow particles through that could clog anything? If say a batch of fryer oil was attained, how is it pre cleaned before use?
   / veggie oil #2
I have been burning processed vegetable oil in my tractor for the last month. My partner and I set up a small processing set up and yield almost 37 gallons of good diesel from each 40 gallon batch we use. I have read about using straight veggie oil, but the process for us is so simple we chose to make it into good fuel. We are now setting up to pay the motor fuel tax on our fuel and burn it in our trucks. That would be a ford diesel and a dodge diesel. The most problem you should have is filters. It is fun running of fuel which costs us $.63 per gallon.
   / veggie oil #3
If you want to experience making biodiesel without any big expense google "kitchen biodiesel" there are articles on how to make it in a 2 liter bottle using drain cleaner and gas line anti-freeze.
After doing it this way if you are handy you should be able to build your own processer. It's not that difficult once you do it in a small amount and see the process.
   / veggie oil #5
Johan 3400, I don't think you need to pay road tax if you use it as an "additive" for lubrication
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
