Vasoline for small hydralic leak
   / Vasoline for small hydralic leak #1
Fatcows
Branson 6530
Hey guys,
New to the forum here. I have a buddy that fancies himself to be a hotshot mechanic, but I'm not sure I trust everything that comes out of his mouht. Ever heard of using vasoline on a hydraulic cylinder to stop a minor hydraulic leak? He claims that it makes the gasket swell just slightly, and usually enough to seal the imperfection.
   / Vasoline for small hydralic leak #2
Sorry a newbie to hydraulics myself but never heard that one. Too much pressure in those cylinders
   / Vasoline for small hydralic leak #3
I use Vasoline to hold O-rings in place, during assembly, not to stop leaks
   / Vasoline for small hydralic leak #4
So, does petroleum jelly makes rings swell, damage them, or have no long term effects?
Depends what the ring is made out of I suppose.
   / Vasoline for small hydralic leak #5
You might use the vasoline to smear on the cylinder rod to prevent rust in storage but that’s about all it’s going to do.
   / Vasoline for small hydralic leak #6
Think vasoline is pretty inert for almost any application....... Its just those foam air cleaner filter that I hit with carb cleaner and they swell up the bothers me....
Dale
   / Vasoline for small hydralic leak #7
I think your mechanic buddy is full of bull shoney.
   / Vasoline for small hydralic leak #8
So hydraulic oil doesn't make the seal expand but vasoline does? I'm not even sure how you would get the vasoline past the wiper on the end of the gland nut. Even then it's on the wrong side of the pressure. Finally every cylinder seal I've replaced is a plastic like material. I'm sure some old ones may be some rubber like material but I have to believe that those compounds haven't been used for decades.
Thanks for the replies. I'm skeptical, but guess I'll give it a shot. If for nothing more than to raz my friend about his mechanic skills when it causes the seals to melt...
   / Vasoline for small hydralic leak #10
It’s not going to make the seal melt. It’s going to do absolutely nothing. You’d need something much nastier like possibly brake cleaner or acetone to have any chance of melting the seal but even that’s probably not going to work.
2008 Ford E-350 Versalift Bucket Van (A50323)
2008 Ford E-350...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
Portable Fuel Tank (A50515)
Portable Fuel Tank...
Grasshopper 618 Zero Turn Mower (A50514)
Grasshopper 618...
John Deere 9450 Combine (A50514)
John Deere 9450...
