Vanguard Starter Gear? (long)
   / Vanguard Starter Gear? (long) #1
To20Chris
Platinum Member
Hereford, PA
LK3054
I was going to title this "Back from the dead (almost)", but I thought I'd focus in the actual question. Here's the story:
The Wheel Horse needs rings, but the way the grass grows around here I can't afford to be out a mower, so I remembered that my Dad had an old rider that broke. Turns out it had a small fire under the hood, but he got it out, and he claims it was still running. Perfect, right? /forums/images/graemlins/grin.gif So I go over and we load it up - it doesn't look too bad - fuel lines are burned, no other obvious damage from the fire. This should be an easy fix! /forums/images/graemlins/grin.gif
It is a NOMA Products mower, with 4WS, a 14hp B&S Vanguard twin, and a 46" deck. It was maintained the way my Dad always takes case of his equipment - the hood is held on be a piece of string on one side, the cooling fins are all blocked up, there is a bungee cord holding the battery in with some Romex making the one connection, battery compartment full of leaves, etc.
So I pull it apart. I notice the starter gear is about 1/3 gone, but it might last a bit. The wire to the electrovalve on the float bowl is burned off, but the air filter housing is OK. The choke cable is frozen, but overall things look OK. I pull the electrovalve off the carb, cut the burned plastic out of the end of it, test it and it still works. I soldered on a new wire, filled the end with epoxy and let it set. I put on new fuel line, and went to work on the battery (charged overnight). I replaced the battery lead, and found the original battery holder under the leaves! I put in a little fuel, but could not get it to the carb. Since the bottom of the tank is below the carb, I figured that the pump might need a prime, so I just filled the tank. I started pretty easily, and ran ok after a bit.
But then I notice it was dripping fuel on the exhaust system, probably the cause of the original fire. I take it apart again, and take the carb off (I cleaned it in place first time). I has some junk in the needle valve seat, which I clean out, and the bowl gasket is broken (a little RTV). When I go to put it back on, I notice that the long metric screw stripped out the aluminum when it came out. I tried to re-tap the hole, but there's nothing left, so I jam in some liquid steel, let it set, and tap it. I sharpened the blades while I was waiting. I put it back together, and it runs great!
I went to put on the blades, and realized I don't have the pins, so I had to make some one of steel rod and cotterpins, and the shorter ones got bolts until I get to TSC. It cuts real nice! I even made a bolt for the hood, and it is all back together. Wife likes it! /forums/images/graemlins/smile.gif
After a couple of hours the deck stops. I find a broken tensioner spring. I heat the end of it up and bend a hook on it, and then I used an end from the bungee my Dad had in there to attach it back on (recycling!). It won't start up again. I look at the safety switches, etc. I pull of the fuel lines at the carb - no fuel. I try the starter to see if the pump is working, and the starter gear stripps /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif. I fugure the fuel got below the level of the carb, the pump isn't working, so it ran out of fuel.
OK, here (at long last) is the question: Is there any way to replace the darned plastic gear without pulling the flywheel? I could pull off the stripped gear, but there is no way a new one will clear the iron flywheel above the ring gear. One of the starter bolts is completely inaccesable, at least for any tool that I have, even the wobbly socket end. The parts will only be about $30, and given the amount of time I have in this now, I'm definetly going to fix it, but I hate pulling flywheels. I have to say, this is one STUPID design, and the kind of thing that makes me not like B&S. I wonder why they sell those gears by the bag full?! I'd much prefer a Tecumseh or Kohler! If anyone has any ideas, I'd appreciate it!
   / Vanguard Starter Gear? (long) #2
Don't pull the flywheel. The starter bolt your referring to is accessible with a home modified wrench. Cut the box end off the wrench. Heat and bend the wrench 45 degrees. Grind the open end down to about 60% of it's original thickness. This is a pain in the hiney but it works. Every lawnmower shop around has a few of these "special" wrenches lying around. /forums/images/graemlins/grin.gif You might even be able to borrow one from your dealer. It would take at least an hour (maybe less, you seem pretty handy) to pull the flywheel with the proper tools. I can bang out the wrench described in less than half that time and you'll always have it. Good luck.
Slam
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
1996 JCB 506B Telehandler (A53473)
1996 JCB 506B...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2007 Kubota L2800D 29HP Utility Tractor (A51691)
2007 Kubota L2800D...
