Vanguard drive pulley
   / Vanguard drive pulley #1
JAMES NICHOLSON
lisbon.ohio
cub super lt1550,ford lgt 100,simplicity,wheel horse, murry
Does anyone know if there is a drive pulley available to fit the flywheel side of a vanguard engine ? I wan't to drive a small hydraulic pump on that side of a 18 hp.
   / Vanguard drive pulley #2
I would advise against it. The overhang would place a tremendous stress on the crank. Is there even a bearing on that side? What's wrong with the PTO side? If you have to use flywheel side, I'd use a direct coupling--Inline with the axis of the flywheel. Simple enough to make one. I think the flywheel is already threaded.
   / Vanguard drive pulley #3
Briggs makes a stub shaft kit that bolts to the flywheel. I have also found that if you use the electric start only version of the engine that the stub shaft extends too far into the fan housing and you have very little length to work with. The stub shaft kit replaces the rope starter making the engine electric start only, but seems like there is a difference in the length of the nose on the flywheel which only allows like 2.5 inches of the stub shaft to extend from the fan screen instead of the complete 4 or so inches of the shaft.
I can drive it off the PTO side but the application would be easier on the flywheel side .
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
15200 (A56857)
15200 (A56857)
2461 (A58376)
2461 (A58376)
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
