vanguard diahatsu sd950 diesel
   / vanguard diahatsu sd950 diesel #1
msg
hutto,tx 78634
jd 2440
i have a 3 cyl daihatsu diesel engine in a mule that has a dead cylinder. anybody had one of these apart? where is the best place to get parts, new or used? thanks. mark
engine runs and keeps oil pressure even when hot, does not loose coolant. im thinking rings or piston? valves are adjusted correctly. lots of blow by but will run all day. anybody have any experience? thanks again
after pulling the head it looks like the rings are gone in #3 cylinder. i can almost see the pan through the gap!!! looks like a have a place to start.thanks
   / vanguard diahatsu sd950 diesel #2
Sounds like time for a new engine or a short block.
Don't know how much you can re bore.
Most small diesels have a very thin cylinder wall, and most are not a wet liner.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
2020 McLanahan 150 TPH USP Sand Plant (A52377)
2020 McLanahan 150...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
