Valve stem/tire warranty question
   / Valve stem/tire warranty question #1
PumpingPete
Bronze Member
Fort Scott, KS
New Holland Workmaster 55
As I was mowing today, I noticed a loud hiss coming from the left rear tire. When I stopped and checked it out, I notice the air was coming out of the valve stem. I couldn't get it stopped unfortunately and had quite a walk back to the truck. Anyways, my question is concerning the warranty on tires. I have had this tractor only a couple of months. Is this something new holland covers under their warranty?
   / Valve stem/tire warranty question #2
You would think so. Is there a u shaped guard on the rim?
I didn't notice one. I have already called the tire shop to place a service call, but didn't know if I should be speaking with the dealer instead.
   / Valve stem/tire warranty question #4
I seriously doubt that New Holland will warranty the valve stem.
I figure it is a long shot, but could have swore I was told the tires had a warranty as well.
   / Valve stem/tire warranty question #6
Around here, some tractor dealers don't do tires, they send you to a local Ag/Industrial tire shop warranty or not. The valve stem probably is a long shot, but it can't hurt to ask.
   / Valve stem/tire warranty question #7
it's such an easy fix if it is a tubless tire.. snatch old stem.. use a squeezevplunger tool to stick a new one in without even debeading tire.....
Where do you get one of these plunger tools?
   / Valve stem/tire warranty question #9
my local tire place uses one. it's some kind of forcing cone. they lube up a vs. cram it in this tapered tube. shove the tube to the hole. do a fast move and grunt, then pull pack and there is a valve stem in the hole.
the remov ethe old one first with a 2 claw tool like a small hammer. it comes out.. thus it can go in..
I have seent hem on the internet too.
can do a valve stem in like 30 seconds, no debead...
   / Valve stem/tire warranty question #10
rear tire wont have rubber valve stem. more than likely hit something and broke it. break one side down to replace 30 min job
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
