Valve stem broke on my rear tire of L2800 Kubota
   / Valve stem broke on my rear tire of L2800 Kubota #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
Hey guys I was doing some work in the woods and I broke the inside valve stem of the rear tractor tire.
Do I have to break the bead to replace it?
Where can I get a new valve?
Any tips\tricks on reloading the tire with antifreeze?
How much antifreeze?
Thanks for any help or advice!
Wade
   / Valve stem broke on my rear tire of L2800 Kubota #2
It is pretty common to damage a valve stem in the woods although inside stems are not usually damaged as often as outside ones. I think a short brass stem is best. When you have the tire broke down, which as far as I know you will need to do, you might consider welding on a 1/2 pipe stem guard. Loaded tires are usually filled to the top of the rim. Do a search to find out how people do the filling. Good Luck.
Thanks. Does anyone have any tricks to breaking the bead and then remounting the bead?
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2014 COTTRELL CX-09LS2 AUTO HAULER (A52576)
2014 COTTRELL...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
John Deere 9470R (A53342)
John Deere 9470R...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
