Valve kit
   / Valve kit #1
AzChopp3r
Show Low, AZ
JD 4300
Hi folks, where is a good place to get a valve kit to run a grapple on the front of my JD 4300? Basically want to tie into rear hyd outlet with quick connect, run hoses to elect. valve which is operated by a switch on the stick, then run hoses to front of tractor and end with quick connect.
   / Valve kit #2
You might want to check with Ken over here. He specializes in John Deere and has the lowest kit price that I know of. My kits are a bit different and cost more.
Good luck;)
   / Valve kit #3
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
Polaris ATV (A50324)
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
