valve help
   / valve help #1
bobcat fan
i need help i have a valve that a wanted to run a cylinder on it is a double acting one function but it has 6 ports so i blocked the two extra on the top and had the pressure in/ out on the side. i hooked it up to the cylinder nothing happened so i disconnected the hoses put them in buckets and fluid came out of both hoses so is this a motor spool or is it broken???
   / valve help #2
There is no way to tell how that valve is configured from your small picture, or even a large one for that matter. Whether it's a motor spool, or DA or SA spool is all internal to the valve.
This is the problem when getting used valves or "deals" of of eBay-you never know what you have. There are no numbers on this?
   / valve help #3
I blew it up to 400%, it was distorted but, I think it is a joystick for a loader.
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2011 NOV ROLLIGON DOUBLE PUMPER (A53843)
2011 NOV ROLLIGON...
2012 RAM 2500 (A53843)
2016 John Deere 5100M (A50123)
2016 John Deere...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
