Valve Gap for ISEKI G174
   / Valve Gap for ISEKI G174 #1
Anonymous Poster
Epic Contributor
One of the cylinder is not fireing, and the Tech wants to know the spec of the Valve Gap, so he can adjust.
also I need advice how to fix the problem.
Thank you in Advance.
First your G174 is a Bolens designation. This model is also the same as a White farm Equipment "Field Boss 16"
The manufaturerer is Iseki whose model is a 2160T or 1550.
The Valve gap I interperet as clearance is .01" or 0.25mm.
I forgot to mention that not firing or missing could be related to many items, poor fuel, blockage in fuel line, valve settings, injector may be fowled.
Start with fuel then valves and then injector. you may need a special tool to remove an injector and most injectors can be repaird or service at a diesel injection repair shop. Also checking compression is adviseable as the basis for diesel combustion is pressure.
Kelly Ryan Bagger (A50774)
Kelly Ryan Bagger...
Truck Bed (A50774)
Truck Bed (A50774)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2025 JMR Tree Boom Skid Steer Attachment (A50322)
2025 JMR Tree Boom...
