valve/fitting questions
   / valve/fitting questions #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I don't know anything about hydraulics (other than how to spell it), so please bear with me...
I posted earlier about adding remotes to my L4200 for a snowblower. The blower and my backhoe seem to have the same fittings - male ends look to be about an inch in diameter. My FEL hoses use smaller diameter fittings (maybe 3/4" dia). I'm guessing that these are the 'most common' fittings - how do I determine what kind and size the fittings are - shape, dimensions, etc?
I want to add 2 remotes for my chute swing and flapper (whatever that is called) controls. It looks like I can just plug into the power-beyond that is currently running my backhoe. A dual lever system would work, but I think a joystick would be even better. At any rate, each control would have to go back and forth, have a relief valve, no float. What type of valve(s) do I need?
Lastly, is it a good idea to get valves with power-beyond capability, or do they all have that?
Thanks - JayC
   / valve/fitting questions #2
Three most common fittings are NPT, JIC, and ORB (also refereed to as SAE). A good size chart with basic descriptions is HERE.
You want basically this: "Open Center, 4-way, 3-position, spring return to center.
Good Joystick valves: 9-7677 or 9-7401 They include adjustable PRV's (pressure relief valves) and are PB (power beyond) capable-no, not all valves are.
Basic 2 spool valves: 9-7862 or 9-7693 Are two basic examples, there are Lots of choices when it comes to valves.
Yes-you want PB (I thought we covered that well in the other thread?)
No, all valves do not have PB capability.
'Kay - thanks for the links. The fitting size chart was all greek to me - no clue what any of that means and still no clue what each is supposed to look like. The fittings I was referring to on my blower and backhoe were the quick-connect ones. My dilemma - the charts all show a couple hundred fitting options, yet everything I see uses the exact same shaped fitting with all of 2 different diameters, but I have no idea what kind it is. I need something with pictures, I guess.
JayC
2019 Hustler X-One 60in Zero Turn Mower (A51691)
2019 Hustler X-One...
2013 Ford F-150 (A53422)
2013 Ford F-150...
2016 Nissan Titan XD SL 4x4 Crew Cab Pickup Truck (A51692)
2016 Nissan Titan...
2014 Broce KR350 (A50123)
2014 Broce KR350...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
