Valve clearances on C123 engines....
   / Valve clearances on C123 engines.... #1
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
I've got a '57 Farmall 230...it has set for a number of months in my barn...I finally started it a couple of days ago...had a miss in one cyl...after checking everything out, I surmised that I had a stuck valve...pulled everything off and sure enough...it was...a bunch of PB Blaster and an amber mallet later its freed up and running correctly (I have some other issues, but I wanted to fix this first)...While I've got it down to this point, thought I'd reset the valves..does anyone remember what the intake/exhaust clearances are??? thanx...BobG in VA
   / Valve clearances on C123 engines.... #2
Both intake, and exhaust, 0.014 hot.
Thanks! Appreciate it!
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
Rock wood travel trailer (A51694)
Rock wood travel...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
