valve clearance on Shibaura 2 cylinder diesel
   / valve clearance on Shibaura 2 cylinder diesel #1
ziptiekid
Brookfield, MO
1984 Ford 1700 4x4 and 1944 Farmall super H
I am reinstalling the repaired head on our Ford 1700, it has a Shibaura deisel (2 cylinder). I need to find out the valve clearance, if you need more info on the motor or what happened you can go to the thread labled "Ford 1700 building pressure in radiator". Thx....Lee
   / valve clearance on Shibaura 2 cylinder diesel #2
Intake and exhaust are the same. .012" (.3mm)
   / valve clearance on Shibaura 2 cylinder diesel #3
Lee,
below you'll find the info. I have checked it with cold engine and it was right at the spec 0.3 mm. Have not checked it with engine runnig .. too much mess.
JC,
Thanks alot guy's..I appreciate it.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
(5) 55 GALLON POLY DRUMS (A51248)
(5) 55 GALLON POLY...
