Hi has anyone adjusted the valve clearance on a CK20 HST? I"m looking for the cover you take off to see the timing marks on the flywheel. One other problem I'm having is tractor is always on the full mark for fuel. I have taken the float assembly out and bent the float rod so the float rides more in the middle of the tank and still stays on the full mark. When I had the float assembly out I could move the float up and down and it would register on the fuel gauge just won't work in the tank. Any help would be appreciated
