Chipper Value Leader Implements wood chipper
   / Value Leader Implements wood chipper #1
bcjmmac
NB, Canada
John Deere 2520
Hi
Anyone have any experience with value leader implements. I'm looking at their 5" PTO chipper as a possible purchase.
   / Value Leader Implements wood chipper #2
I got a 5' fail mower from them a couple of years ago ,and have had a few problems with it . First of all the lowest sitting on the adjustment would not line up on the skids ,so i had to grind some off to get it to line up. The roller on the back that it rides on broke on one side next to the outer bearing ,which I had to get welded so I did both side . The seal around the shaft is leaking and that happened only after i'd mowed my field once(8 acre ) not enough to tear apart yet I just keep an eye on it . The blades where not hardened steel so they bend and wear more . I guess what they say rings true "You get what you pay for" ,but sometimes that's all you can do. I found out that it pays to research , research ,research then do it again, good luck and if you get it, let us know what you think of it.
   / Value Leader Implements wood chipper #3
I have their 4' flail mower. I think it's a good value --- I've had a few problems with loose bolts. Those were all basically on delivery --- once I found them all and tightened them up, no issues since. I've used it a half dozen times and have about 8 acres total on it. I wouldn't buy it to mow all day, every day --- for occasional use it seems just fine.
   / Value Leader Implements wood chipper #4
Hi
I have one of their 68" flail mowers. Works OK on my 6-acre hayfield clearing stubble. The threads are stripped on the grease zerk that's on the pulley end of the main shaft. Need to fix this before I use that mower again. So far that's the only glitch.
Good luck.
   / Value Leader Implements wood chipper #5
I'm glad I spotted this thread. Hahahaha.
I'll be spending the extra money and buying a Caroni.
Thoughts on if the 26 hp (20 claimed @ Pto) my tractor makes will be enough for a 5' unit or if I should stick with a 4'.
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
