Value and info on Danuser (Dearborn Equipment) blade
   / Value and info on Danuser (Dearborn Equipment) blade #1
Milburn, OK
Ford 1510
Hello everyone,
I've been looking for a 6' blade for some time now, and I came across this Danuser that is in decent shape but missing a few parts. The owner is asking $250, and I'm wondering if this is a fair price?
Also, the bearings aren't frozen or anything, but they will likely need replaced as will the grease cap. How hard are these to find and replace, and what would be the cost of the parts?
Thanks in advance!
   / Value and info on Danuser (Dearborn Equipment) blade #2
What bearings on a rear blade could need replacing? Where does it even have bearings? Looks like it has only one moving joint. I'd think grease it and call it good.
   / Value and info on Danuser (Dearborn Equipment) blade #3
Kind of UGLY, but I'm sure a whole lot better then a lot of the junky blades being made today. Those nameplates are priceless. When Quality, Pride and experience meant something and not just some slick sales BS.
   / Value and info on Danuser (Dearborn Equipment) blade #4
   / Value and info on Danuser (Dearborn Equipment) blade #5
No the upper arms going to the top 3point link are flat steel on a 1952 model. Still using Grandfathers bought new in 52.
   / Value and info on Danuser (Dearborn Equipment) blade #6
That was made when steel had more carbon in it, which made for a tough long lasting product. I'd buy it.
Look at where the spindle comes from the top of the moldboard up through the pipe that runs straight back from the lift arms. (Where the moldboard pivots left and right) The grease cap is missing, and there are some relatively large bearings inside there.
Definitely ugly, but probably better quality than any other blade I could buy around here. I looked at Atwood's and Tractor supply. Needless to say, I wasn't impressed.
   / Value and info on Danuser (Dearborn Equipment) blade #9
There are actual bearings? That's impressive. I think most have just a shaft running in a steel sleeve.
   / Value and info on Danuser (Dearborn Equipment) blade #10
If you use it for snow, the lack of paint could make the snow not want to slide off. Do you even get snow?
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A55315)
2017 Cadillac...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
John Deere 4820 Forklift (A57453)
John Deere 4820...
