Valtra 6850....considering buying one. opinions?
   / Valtra 6850....considering buying one. opinions? #1
FrankMaddock
Entwistle, Alberta, Canada
McCormick MTX 110, CIH JX75, MF 1020, IH TD 15B, CIH VT185
I have been looking closely at buying a used Valtra 6850 . Smoking price. and reverse station too. Looking for comments and experiences. I understand AGCO isn't importing them to Canada any more. Though the AGCO dealer says parts are available. Be ruthless and brutal if you must.
   / Valtra 6850....considering buying one. opinions? #2
Mostly a good tractor. Sisu engine is perhaps one of the most easy to start engines in the cold. These tractors are pretty common where I live so I've run some variations throughout the years, do you know if it's turbine clutsh in this?
If so, it takes a little time to learn to drive it especially down hills With a trailer when the turbine clutch do not hold back in the same way as a conventional tractor.
Valtra 6850 Hi-Tech - Valtra - Machinery Specifications - Machinery specifications for new and used machinery - Werktuigen.com
What do they use for a power shift? 3 speed? 4 speed? 2 speed?
   / Valtra 6850....considering buying one. opinions? #4
4 speed in 3 series
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
1964 Mercedes (A51694)
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
CIERZO ELECTRIC AIR COMPRESSOR (A51248)
CIERZO ELECTRIC...
