Vac case
   / Vac case #1
mmckim90
Brashear, MO
JI Case
Needing to know what kind of starter I can put in my vac case I had the original rebuilt but it has went out again and is not able to be rebuilt again any info would be great thanks.
   / Vac case #2
What is causing it to go out..?? Sounds like there may be other issues, and no matter what starter you put in, it may happen again. Why is yours beyond repair..?? Unless the case is damaged beyond repair, everything else can be replaced, in a rebuild. I would trust a total rebuild by a competent local shop, than buying a rebuilt "pig in a poke" online. Most of those type only replace what's needed, when tested. By that I mean, it may only need bearings, and that's all they will be replaced. If the armature is nearly worn out, but yet with some cleaning up where the brushes run will pass, they'll clean it up on a lathe, and reassemble, and send it out the door.
There are many aftermarket vendors that can sell you an OEM rebuilt starter. Take your choice. Go to Case/IH online parts store, and find the part number for your starter, then do a Google search of that part number. I'm sure you'll get a ton of hits. Check in the description, and see if they say what parts were renewed/replaced. Then shop for price.
   / Vac case
I致e looked online and can稚 find a starter rebuild kit anywhere.
   / Vac case #4
Check around for local starter/alternator/generator repair shops. They should be listed in the Yellow Pages, or ask friends, neighbors,or local farmer's. Here, if a starter, generator, or alternator just need bearings and brushes, and armature cleaned up, I can get that done for $35-$40, with a 1 year guarantee on parts & labor. If the armature is toast, those will run around $100+ alone.
Most rebuild's I've seen online, or in store only have a 90 day warranty.
   / Vac case #5
Hi I agree with DJ54 We have a have an amish gentleman near here that can fix any starter He just orders the part needed and fixes it, here in central wisconsin. At a fair price. no rebuild kits I have some manuals for VAC that I would part with, if interested. Good Luck Kenny
   / Vac case #6
If you can't find anything closer, there's an Amish starter/alternator shop NE of Trenton!
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
3pt Fertilizer Spreader (A50120)
3pt Fertilizer...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
