UTB Universal 445DT rear hydraulic lifter not lifting
   / UTB Universal 445DT rear hydraulic lifter not lifting #1
uncle888
UTB Universal 445DT
Hello all, My 50 year old UTB Universal 445DT has inoperative rear hydraulics. For the past 45 years the rear lifter has only been used once or twice per year and now does not lift at all. I have determined that the hydraulic pump at the engine is working normally and there is plenty of fluid showing on the dipstick near the gear lever. The seat has been removed and the large plug on the hydraulic mechanism removed. I can see that there is no fluid in there which might not be surprising because there is evidence of a seep around this area.
My question is - does the absence of hydraulic fluid indicate that there is a blockage or does this area need topping up separately from the gearbox?
Problem solved. It was a sticky valve at the top, front, under the seat.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2006 Ford Explorer (A47384)
2006 Ford Explorer...
Onsite begins 8:30am / Online begins 9:30am (A50121)
Onsite begins...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
