UTB/Montana
   / UTB/Montana #1
deepwoods
NC
Hi. Does any of you guys know what UTB model # is the same tractor as a Montana C5264? It has a 3 cylinder deisel with 172.087 ci displacement. Trying to determine it to check parts availability . Thinking of buying the Montana, found out UTB has closed down .
   / UTB/Montana #2
Not for certain, but the C5264 is 52hp, and UTB's 524 was also 52hp. There was also the 533 which was listed as 53hp....
   / UTB/Montana #3
you might be able to find something if you go to importtractorparts.net, not sure if you will find your montana, but it doesn't hurt to try, good luck in your search
   / UTB/Montana #4
2015 DODGE RAM...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
40ft Sea Container (A52384)
40ft Sea Container...
2022 Mercedes-Benz Sprinter 4500 (A51692)
2022 Mercedes-Benz...
2011 Deere 650J (Camilla, GA) (A50123)
2011 Deere 650J...
