Using Semi-Trash Pumps to spray water...
   / Using Semi-Trash Pumps to spray water... #1
rjwerth
Outside of Detroit, MI
DK50SE Cab
Looking at getting a semi trash pump from Northern tool. The initial purpose is to drain and refill a 1/2 acre pond but for long-term use, I need it to do other things. How good are these at watering gardens or putting out a brush fire? I see they have "high pressure" pumps but they don't handle mud or crud well. Pricing is around the same so I just want to get the most versatile thing I can for the long-term.
Thanks.
   / Using Semi-Trash Pumps to spray water... #2
As you have probably noticed a trash pump is better for high volume at a low pressure delivery whereas the high pressure pump has a lower volume for the same hp. fighting a fire would require a higher pressure to spray a stream of water the greater distances needed. Watering your garden, pumping out the pond are better suited to the trash pump. Now you can get a high pressure pump that will match the delivery of a given trash pump but it will be more expensive and require more hp to utilize.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
ALLISON TRANSMISSION (A53843)
ALLISON...
CAT RM-300 (A53843)
CAT RM-300 (A53843)
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
