Using Round bales?
   / Using Round bales? #1
mathey
Platinum Member
MD
NH TC33D
We've always used large square bales to feed our horses, but this year my FIL switched to the smaller round bales. So I now have 4 of them sitting in my barn (with 91 in storage!). My wife and daughter are having a tough time peeling hay off the round bales...they used to just give each horse a "flake" off the sqaure bale...
Is there some trick or method to using a round bale just a little at a time (as opposed to ploping the whole bale out in the field)? I've seen antique hay knives/saws, but nothing "new".
THX!
THX!
   / Using Round bales? #3
The only way I've seen people use round bales to feed horses is by using a round bale feeder, like this.
   / Using Round bales? #4
   / Using Round bales? #5
I've never known anyone who used one, but the bale unroller would work, but it's really only for feeding the whole bale at a time. I've "peeled" off enough from round bales to thoroughly understand your problem, but don't know of a good solution. /forums/images/graemlins/laugh.gif
   / Using Round bales? #6
   / Using Round bales? #7
mathey,
I feed horses and cows with round bales and here's what I've found. If your horses are used to having a brick or two off a square bale fed to them every day, at first they will eat more than normal off the round bale. Kind of like a kid with an unlimited supply of something they like. However, after a couple to 4 days, the horses realize that you are not going to remove that round bale and settle down. Basically then, they only eat what they need. You need to get a round bale ring though, in order to stop them from just spreading it all over and wasting a bunch.
   / Using Round bales? #8
mathey,
   / Using Round bales? #9
</font><font color="blue" class="small">( You need to get a round bale ring though, in order to stop them from just spreading it all over and wasting a bunch. )</font>
Expect a lot more waste even with the ring.
   / Using Round bales? #10
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2012 PETERBILT 587 SLEEPER (A54313)
2012 PETERBILT 587...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
