Rear Blade Using Rear Blade with Rear Ballast
   / Using Rear Blade with Rear Ballast #1
cbh
Bronze Member
I just received a Midwest RB22-60 rear blade for my B7500, mainly to use for snow removal. I am assuming that when the rear blade is resting on the ground, it no longer puts weight on the rear wheels. I do have rear tire chains, but am wondering whether the rear of the tractor will be too light when plowing with the blade or moving snow with the loader.
The B7500 owner's manual implies that rear wheel weights are not recommended, although liquid tire ballast is okay. I have been using a ballast box for rear wheel traction in lieu of filled tires. This was so I could easily remove the ballast when driving over the lawn. However, the ballast box can't be used with the blade. Any thoughts on this? Thanks.
   / Using Rear Blade with Rear Ballast #2
You won't need added weight for pushing snow with a rear blade. Works just fine without it. The tire chains will be a big help though.
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
