arkydog
- Joined
- Jun 16, 2002
- Messages
- 364
- Location
- Arkansas
- Tractor
- kubota 3200hst loader and bh77 backhoe, allis chalmers 816 backhoe
Hey everyone. I was wondering if anyone had, or thought about using an inboard/outboard Mercruiser outdrive hydraulics from a boat that are 12v activated to run say an upper grapple arm on a front loader bucket instead of tapping into the tractors hydraulics? It would seem that it should work because i think everything is there. The two cylinders for opening and closing the grapple, the releif valve, the hydraulic pump, and the motor. the hydraulic hoses would probably have to be made longer, but that shouldn't be much of a problem. I'm thinking that there wouldn't need to be all that much pressure to hold the brush in the bucket unless you were trying to hold tree trunks, at which time you could chain the trunk on. This all works to open and close the grapple.
The pump and motor are all in one unit and could be mounted on the grapple mount with only the wires running back to the dash with a quick connect electrical plug near the pump.
Any ideas either pro or con?
Thanks Rob
Thanks Rob
