USING OIL JINMA Y 380
/ USING OIL JINMA Y 380 #1
DUMMASS
PHELAN ,CALIFORNIA
NORTRAC NT-204C /Jinma Y380 engine
OK ,FIRST NOT RUDE. OR YELLING JUST OLD & BLIND.........MY JINMA Y380 IS JUST STARTED USING OIL,GOT ABOUT 400 HRS ON IT I THINK AS THE HR METER QUIT @ 350.45 2 WEEKS AGO.
IT STARTED USING OIL AFTER THE LAST OIL CHANGE @ 350 HRS, ADJUSTED VALVES @ THAT TIME ALSO.
I NOTICED IT STARTED SMOKING BLACK SMOKE, ALSO SMOKE COMING OUT OF THE (I THINK IT'S A BLOCK VENT IT'S BEHIND & LOWER THAN THE EXHAUST & HAS A WIRE MESH FILTER)..IT IS ALSO STARTING TO GET WARM 200 DEGREES F..
NO NOTICEABLE BLOW BY W/OIL FILLER REMOVED...
IT STARTS FINE,WILL CHECK COMPRESSION MONDAY .. ANY OTHER IDEAS OTHER THAN RINGS,VALVE GUIDE SEALS,,,
OIL PRESSURE BETWEEN 35 PSI @ IDLE -55-60 PSI@ OPERATING SPEED..:confused::(:irked::censored::censored::censored:
/ USING OIL JINMA Y 380 #2
That "wire mesh filter" you identified is the crankcase breather. It requires periodic cleaning. If this is not already part of your maintenance schedule, I recommend you remove it and wash with kerosene at least yearly. Consider also that the engine oil filter may be bypassing. Doesn't cost much to replace it. May as well change the oil while you're at it. Also, remove the valve cover and wash it out. Then use a paint brush to wash away the crud on and around the valves. You'll then find a few oil ports, where splash lubrication passes between head and crankcase. One or more may need unblocking. Because of the potential of contaminating the crankcase with kerosene, this should be done before you change the oil and filter.
//greg//
THANKS GREG .
I TRULY APPRIECIATE THE ADVICE
CHANGED OIL 15W-40 DELO ,NAPA GOLD FILTER 1513, TOOK OFF VALVE COVER CLEAN LIKE NEW NO SIGNS OF SLUDGE OR "CRAP" ANYWHERE LOOKED LIKE NEW UPPER END......CLEANED CRANK CASE BREATHER AGAIN, STILL GOT OIL COMMING OUT OF THE BREATHER....HOWEVER WHEN I PUT THE VALVE COVER ON THERE WAS NO SIGNS OF "BLOW BACK" FROM OIL FILL HOLE?????????????????
HOW HARD IS IT TO FIX THE RINGS IN A TRACTOR? I'VE REBUILT QUITE A FEW ENGINES IN MY 50+ YEARS, HOWEVER I'VE NEVER TORE DOWN A TRACTOR...PLUS HOW HARD ARE INTERNAL ENGINE PARTS TO GET (LEAD TIME)?I'D APPRECIATE ANY HELP ....JIMNA Y380 ENGINE NORTRAC NT-20C 3 CYLINDER DIESEL, 20 HP..THANK GUYS & GALS:drink:
/ USING OIL JINMA Y 380 #5
dummass:
these things are not too bad and parts can be had at several state side businesses in a few days. Affordable is great he posts here a lot and has great parts counter and supply on hand. There are a few others here too that also have a very good parts supply.
Mark
/ USING OIL JINMA Y 380 #6
I changed oil in a Jinma 254 that I had just bought and it smoked and blew oil out the crank case breather just like you are saying. I had put in 6 1/2 qts like it called for. That was too much oil. I redid it and it actually held just over 5 qts. No more smoke and no blow by. Pat
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
Topcat ECSSSTG200 (A60463)
Topcat ECSSSTG200...
