Using loader in low range sure makes difference
   / Using loader in low range sure makes difference #1
cdcole
Wisconsin
TC25D
Today - after the pressure adjustment - I spent some time filling some low spots. My wife had some dirt delivered about 3 years ago. The pile had hardened and I was "attacking" it in 2nd range (always mow in this range). Yes I know the reasons why the low range will give you more torque but I simply forgot to drop it into low range until I bogged down a couple of times. I finished the digging portion of the job in range 1. Just a reminder of the extra power in range 1.
   / Using loader in low range sure makes difference #2
Yes. I have found the same. It also helps to keep the throttle opened up a bit so the hydraulics do not bog down. I keep the hand throttle set at some minimum level and then use the foot throttle to boost it up as needed.
The trade off is a low enough gear and range combination to allow you to load it up and then move off at a decent speed.
But if you keep it in a lower range and then shift between the low and high gear it works out pretty well, IMHO.
Fred
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
Kubota 48in Loader Bucket (A50322)
Kubota 48in Loader...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
