Using jump start battery for main tractor battery
/ Using jump start battery for main tractor battery #1
arkydog
Arkansas
kubota 3200hst loader and bh77 backhoe, allis chalmers 816 backhoe
hey all. i have a kubota b3200 tractor and was wondering if you could use a 12v 22amp hour agm battery for running in the tractor in place of the original battery. this battery is out of a Jump N Carry jump box. it will start up to 10 dead cars before it won't start any more cars.
i have used it on my own personal car when the alternator quit working on a trip and when i applied brakes to stop the engine quit running the car battery was so discharged. i jump started the car, left jump box attached and drove it 12 miles (20 min. trip) using brake light also, to repair shop.
do u think this kind of battery would work in a tractor? just curious.
/ Using jump start battery for main tractor battery #2
Sure you could use the little battery. I would not, because even in the south, it take a lot of current to start a diesel in winter. Second, the starter will have to draw more current because of the voltage drop.
/ Using jump start battery for main tractor battery #3
I think you would shorten the life of the jump battery. It was not intended to be cycled like a starting battery. Also, the diesel will draw more amps than a gasser. It is better on your equipment to have more amps available in a battery than not enough.
/ Using jump start battery for main tractor battery #4
I wouldn't think that would work for long.
That said I use a U1P-7 275 cranking amp lawn tractor battery in several applications including my 24 HP JD and have for years. Ran 1 in my Mustang for 5 years and had to replace it with same. Have had one on my gate opener with a 30w solar charger for over 3 years and the one in my tractor is about 3 years old. < $30 at wally world.
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
John Deere 3010 Tractor (A66408)
John Deere 3010...
County Line 3Pt Bale Spear (A66408)
County Line 3Pt...
John Deere 530 MoCo (A66408)
John Deere 530...
2022 EZ-GO ELITE...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
