Using JD 4120 rear remotes for Grapple
   / Using JD 4120 rear remotes for Grapple #1
whitedogone
Central Illinois
JD 4120
Well I finally got around to finishing the plumbing of our Wildkat 48" econo grapple that we got late last year. I didn't want to go to the expense or trouble of an elec/over hydro setup. But I didn't want to drape lines up and over fenders either. I got all my lines/fittings from Discount Hydro. It ran about $220. I borrowed a portable fitting press from a buddy.
Coming out of the rear remotes, I switched everthing down to 1/4" lines and fittings:
Although I rarely got without the loader on, I wanted the option of a quick disconnect if needed. So, I made a bulkead fitting mount that I connected to the loader mount with some SS hose clamps.
I continued up the loader in similar fashion as Deere did on the other side. I fashioned a bracket same as the deere one on the other side at the top because Deere wanted over $30 for the same thing:
I fabricated another bulkhead out the loader arm so it would be a quick deal to hook up to the grapple and get to work. I had to adapt back up to the Wildkat supplied 1/2 fittings here. It's kinda bulky, so I may change to 1/4 lines on the front end as well.
I did have some issues with getting it to work correctly, After a few hours diagnosing what the problem was, it was found that 2 of the 1/4" Discount QC fittings were not letting fluid thru. I replaced them and everything is fine now.
2016 Ford Escape SUV (A48082)
2016 Ford Escape...
2009 Ford Fusion SE Sedan (A48082)
2009 Ford Fusion...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2014 Jeep Cherokee Latitude AWD SUV (A48082)
2014 Jeep Cherokee...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
