rockinmywaypa
Platinum Member
- Joined
- Jul 10, 2003
- Messages
- 615
- Tractor
- john deere 3130, universal case 970 and a IH 1086
The title is the best description that I can come up with. This is what I want to accomplish ..... I want to be able to control a cable so that it only feeds out from a drum at a certain predetermined linear force or drag or pull however you want to describe it. This is part of a machine I'm going to put together to pack silage into a bag, I want to hold the machine to the bag so that the cable attached to a gate at the end of the bag feeds out as the bag is being stuffed full but at a predetermined force on the plastic so that I know it is being packed full. I have tried a hydraulic orbital motor but the oil can flow through it even without much rotary force applied to it. would a gear pump/motor be positive enough so that it would hold against the turning force of the drum shaft until a bit of oil is released through a pressure relief valve but not until. The reason this appeals to me is because I could have an either/or valve and switch over to a regular valve to speed the cable in when the bag is full or between setups and then switch back when filling so that the filling force pushes against a pressure relief valve and it is self controlling. Sorry about needing to use a thousand words to get to one picture.
